ASUS U52F-BBG6 Camera Replacement
  1. ASUS U52F-BBG6 Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS U52F-BBG6 Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Scrape off the black circle rubber cushions with your index finger at the bottom frame of the screen.
    • The cushions may no longer be adherent and a bit of glue may be needed to reattach them.
    • Unscrew the two 3mm Phillips screws on the bottom of the frame with the J1 screwdriver.
    • The two 3mm Phillips screws are hidden behind the cushions.
  2. ASUS U52F-BBG6 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS U52F-BBG6 Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool into the crack where the plastic of the screen's frame meets the shell at the top.
    • Be careful not to scratch the screen with the opening tool.
    • Gently twist and slide the tool to open it. The plastic will snap as the frame is released.
    • The snaps that hold the frame to the shell are fragile.
    • Continue to pry with the opening tool or use your fingers until the top portion of the frame releases.
  3. ASUS U52F-BBG6 Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS U52F-BBG6 Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the screen frame towards you so that the seam between the frame and the bottom of the screen is opened.
    • Insert the opening tool into the seam.
    • Peel the metallic strip with your finger and thumb until it's fully off.
    • Place the remaining frame down on the keyboard.
  4. ASUS U52F-BBG6 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS U52F-BBG6 Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed side of the black spudger to remove the metallic stickers by the circuit board of the camera above the screen.
    • Do not remove the sticker completely.
  5. ASUS U52F-BBG6 Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS U52F-BBG6 Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the camera's circuit board by using the flat side of the spudger.
    • The adherent on the camera's circuit board is very sticky.
  6. ASUS U52F-BBG6 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS U52F-BBG6 Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Holding the camera's circuit board with your right hand, use your left index finger and thumb to unplug the micro white hook from the camera.
    • The micro white hook is fragile.
Ashley DeHuff
crwdns2935283:009/15/16crwdne2935283:0
852 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 1-3, Bruce Fall 2016 crwdns2935289:0CSU Fullerton, Team 1-3, Bruce Fall 2016crwdne2935289:0
CSUF-BRUCE-F16S1G3
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 283
