ASUS U46E-RAL7 Back Panel Removal Guide
  1. ASUS U46E-RAL7 Back Panel Removal Guide, ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two (2) 9mm x 4mm screws from the back panel with the size 0 Phillips head screwdriver.
    • Remove two (2) 7mm x 4mm screws from the back panel with the size 0 Phillips head screwdriver.
    • Remove six (6) 7mm x 4mm screws with the size 0 Phillips head screwdriver.
    • Remove three (3) 3mm x 3mm screws with the size 0 Phillips head screwdriver.
    • Remove one (1) 4mm x 4mm screws with the size 0 Phillips head screwdriver.
  2. ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber caps (4) with the tweezers. If the rubber caps are not removed easily, pull gently. The caps are glued down.
    • Remove four (4) 7mm x 4mm screws with the size 0 Phillips head screwdriver.
  3. ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the L shaped panel with the plastic opening tool by inserting it into the indent along the USB port side of the laptop.
    • Push down gently on the plastic opening tool until part of the panel pops up.
    • Use your fingers to pop the panel off.
  4. ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three (3) 5mm x 4mm screws with the size 0 Phillips head screwdriver.
    • Remove one (1) 4mm x 4mm (closest to the battery) screw with the size 0 Phillips head screwdriver.
  5. ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the CD ROM drive by inserting the plastic opening tool between the drive and the laptop's side.
    • Push down gently to eject the drive.
    • Pull the drive straight out to remove the part from the laptop.
  6. ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  7. ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device so that the laptop will open away from you to remove the hinge cover behind the screen.
    • Place index fingers underneath the hinge cover and gently pull up.
    • The cover will pop off easily with a click.
    • Remove five (5) 5mm x 4mm screws from the hinge compartments of the device with the size 0 phillips head screwdriver.
  8. ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the screen.
    • Carefully lift the keyboard panel. The keyboard will be attached to the motherboard by two ribbons.
    • To disconnect the ribbons, use your fingernails to push down gently on the protruding plastic at the base of the connector. There is a soft click and ribbon releases. Repeat for the other ribbon.
  9. ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS U46E-RAL7 Back Panel Removal Guide: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the keyboard from the computer to reveal the motherboard.
Vanessa Ng
crwdns2935283:001/19/17crwdne2935283:0
419 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-1, Mathisen Winter 2017 crwdns2935289:0Eastern Washington University, Team 1-1, Mathisen Winter 2017crwdne2935289:0
EWU-MATHISEN-W17S1G1
crwdns2942667:0crwdne2942667:0 846
