ASUS Transformer Book Flip TP500LA Trackpad Replacement
  1. ASUS Transformer Book Flip TP500LA Trackpad Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Transformer Book Flip TP500LA Trackpad Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Transformer Book Flip TP500LA Trackpad Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
  2. ASUS Transformer Book Flip TP500LA Trackpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Trackpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
  3. ASUS Transformer Book Flip TP500LA Trackpad Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Trackpad Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
    • Pull the blue tab to remove the ribbon.
  4. ASUS Transformer Book Flip TP500LA Trackpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Trackpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 5 mm Phillips #0 screws.
    • Remove the single 6 mm Phillips #0 screw.
  5. ASUS Transformer Book Flip TP500LA Trackpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Trackpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
    • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
  6. ASUS Transformer Book Flip TP500LA Trackpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Trackpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
    • Slide the battery out from the computer to remove.
  7. ASUS Transformer Book Flip TP500LA Trackpad Replacement, Trackpad: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Trackpad Replacement, Trackpad: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The trackpad is nestled into a small cutout on the opposite side as the fan.
    • Remove the trackpad from the device.
Graham Haigood
crwdns2935283:002/23/21crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G3, Eggleston Spring 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G3, Eggleston Spring 2021crwdne2935289:0
CMCSC-EGGLESTON-S21S3G3
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 220
