ASUS Transformer Book Flip TP500LA Battery Replacement
  1. ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
  2. ASUS Transformer Book Flip TP500LA Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
  3. ASUS Transformer Book Flip TP500LA Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
    • Pull the blue tab to remove the ribbon.
  4. ASUS Transformer Book Flip TP500LA Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 5 mm Phillips #0 screws.
    • Remove the single 6 mm Phillips #0 screw.
  5. ASUS Transformer Book Flip TP500LA Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
    • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
  6. ASUS Transformer Book Flip TP500LA Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
    • Slide the battery out from the computer to remove.
crwdns2935229:015crwdne2935229:0
Garrett Fitzpatrick
crwdns2935283:004/10/17crwdne2935283:0
843 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S13-G5, Forte Spring 2017 crwdns2935289:0Cal Poly, Team S13-G5, Forte Spring 2017crwdne2935289:0
CPSU-FORTE-S17S13G5
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 11,730
