ASUS TUF Gaming FX505DY Battery Replacement
  1. ASUS TUF Gaming FX505DY Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS TUF Gaming FX505DY Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS TUF Gaming FX505DY Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an ESD-safe spudger, disconnect the battery connector by pulling the plug away from its port.
  6. ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6 mm screw holding the battery in place using a Phillips #1 screwdriver.
    • Avoid cutting, puncturing, or otherwise damaging the battery. Li-ion batteries can combust or explode if damaged.
  7. ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the retaining pin into the closed position to allow the battery frame to be removed.
  8. ASUS TUF Gaming FX505DY Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery up out of the computer.
Ronald Brodeur
crwdns2935283:003/30/22crwdne2935283:0
109 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-4, Mellen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 2-4, Mellen Spring 2022crwdne2935289:0
UMASSD-MELLEN-S22S2G4
What Is the serial number of the battery ?
Hector Garcia - crwdns2934203:0crwdne2934203:0
Can anyone tell me where to purchase a replacement battery? I have contacted the manufacturer who will not provide any information other than the usual, "Drop off or post your laptop to a service centre near you. Do not attempt to change the battery yourself. For your details of your nearest repair centre please provide your location".
shybunny - crwdns2934203:0crwdne2934203:0
Hey there, thanks for your question! Batteries can be purchased from online retailers, such as Amazon. Before you purchase a battery, make sure you have written down, photographed, or removed the old battery for reference. Make sure the connector, voltage, and shape match. Model numbers shouldn't change but can, and capacity (in Wh or mAh) can vary from the OEM version. Check the return policy just in case, and remember that if purchasing a 3rd-party model there may be a higher chance for a defect.
Benyamin Claxton -
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 3,605
