In order to remove your hard drive for any reason, take the following steps to do so correctly.
With your finger, push this slide to the right. The battery should pop out of place.
Pull the battery out of its place gently.
Lift up the flap using a plastic opening tool.
Hold the flap back with your finger.
Unscrew the 5.2mm screw underneath the flap.
Once the screw is out, pull on the plastic tab to pull off the plastic cover.
Unscrew the 5.2mm screws holding the hard drive in place.
Gently pull the rubber hard drive mount to the side.
Pull the drive out.
