crwdns2942287:0crwdne2942287:0 ↓
Chip ID for the Asus ROG Ally gaming handheld.
Check out our Asus ROG Ally teardown for more details.
Many thanks to our community member CChin for his contributions!
crwdns2936621:0crwdne2936621:0
crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Asus ROG Allycrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
    1. ASUS ROG Ally Chip ID, Main Board Side 1: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ROG Ally Chip ID, Main Board Side 1: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • AMD 100-000001278 3.3 GHz octa-core Ryzen Z1 Extreme applications processor
      • Samsung K3LKBKB0BM-MGCP 4 GB LPDDR5 SDRAM memory
      • Renesas ISL9241HRTZ Li-ion SMBus buck-boost battery charger
      • onsemi CAT24C512 64 KB serial EEPROM memory
      • Realtek ALC3288 audio codec
      • Cirrus Logic CS35L51X audio amplifier
      • Monolithic Power Systems MP2845A multi-phase controller
    2. ASUS ROG Ally Chip ID: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Monolithic Power Systems MP86949 45 A power stage
      • Texas Instruments TPS51285ARUK dual synchronous step-down controller w/ LDOs
      • Silergy SY8388ARHC 8 A synchronous step-down regulator
      • Silergy synchronous step-down converter (likely)
      • Monolithic Power Systems DC-DC converter (likely)
      • Torex Semiconductor XC6223K3019R-G 300 mA / 3.00 V LDO regulator
      • Texas Instruments TMUX154ERSWR 2-ch. SPDT analog switch
    3. ASUS ROG Ally Chip ID: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Kinetic Technologies KTS1690AEGAA-TA USB VBUS load switch
      • Kinetic Technologies KTS1681AEUZ-TR 4 A over-voltage protection
      • Kinetic Technologies Dual Output Load Switch with OVP ?
    4. ASUS ROG Ally Chip ID, Main Board Side 1 - Sensors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Bosch Sensortec BMI323 6-axis MEMS accelerometer & gyroscope w/ temperature sensor
      • Likely Texas Instruments temperature sensor
    5. ASUS ROG Ally Chip ID, Main Board Side 2: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ROG Ally Chip ID, Main Board Side 2: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • ITE Tech IT5125VG-192 keyboard & embedded controller
      • ITE Tech IT8856FN USB type-C power delivery controller
      • Genesys Logic GL9755 card reader controller
      • Winbond W74M25JW 32 MB authentication flash memory
      • MEMS Microphone
      • ANPEC Electronics APL6012 15-ch., 8 bit A/D converter
      • Renesas mixed signal array (possibly)
    6. ASUS ROG Ally Chip ID: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Monolithic Power Systems MP86903C 30 A power stage
      • Infineon IR3883MTRPBF 3 A synchronous DC-DC buck regulator
      • Global Mixed-mode Technology G9661M 3 A / Adj. LDO regulator (likely)
      • Texas Instruments TPS22975DSG 6 A load switch
      • uPI Semi uP9030Q power distribution switch (likely)
      • Texas Instruments TS5A3166DCKR 1-ch. SPST analog switch
      • Texas Instruments SN74LVC1G08 single 2-input AND gate
    7. ASUS ROG Ally Chip ID: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    8. ASUS ROG Ally Chip ID, Main Board Side 2 - Sensors: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    9. ASUS ROG Ally Chip ID, Joystick Board Side 1: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ROG Ally Chip ID, Joystick Board Side 1: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Likely ITE Tech IT8237FN248A embedded controller
      • Likely ITE Tech IT8237FN120A embedded controller
      • SG Micro SGM5200 16-ch., 12 bit, 1 MSPS A/D converter
      • SG Micro SGM4040B-2.5 2.5 V voltage reference
      • Possibly Awinic AW86223 haptic driver
crwdns2947412:011crwdne2947412:0
Any identification for Wi-Fi and Bluetooth? I don't see anything mentioning what it has.
Parker Reed - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The board in the teardown video (I suspect this same board) has soldered on module with a MediaTek MT7922A12L.
Alisha C - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Ally came with MediaTek MT7922 (RZ616). Since it has apparent issues with keeping a connection (not caused by the signal!) - I ordered an Intel AX210 to replace it, only to find out that it's apparently soldered and can't be replaced. This should have been mentioned by ifixit - definitely a bad decision! same for the soldered 16GB RAM. Another bad decision. Now I don't know what to do with the Ally. Unreliable Wifi is no option, so maybe return it..
lucker#1 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What is the function of the empty cable port above the QR code?
李龙啸 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I wanted to update the BIOS, my console stopped turning on so now it is necessary to reprogram this BIOS but I can't find the file on the web, could you help me with a copy of your BIOS, I would be very grateful. To make a copy of the BIOS you could use the CH341 programmer
kevin mosquera - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 21
crwdns2936753:07crwdne2936753:0 151
crwdns2936753:030crwdne2936753:0 649
crwdns2942667:0crwdne2942667:0 30,753
