When replacing a motherboard, it's crucial to select a compatible replacement and consider factors like form factor, chipset, and socket type. Additionally, users should ensure they have proper technical knowledge or seek professional assistance, as motherboard replacements can be complex and may require transferring components from the old motherboard to the new one.
Remove ten 2 mm screws using a Phillips #0 screwdriver.
Remove the screw in the center using a T4 Torx screwdriver.
Use an iFixit opening tool to pry open the back panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the four 2 mm screws from the battery using a Phillips #1 screwdriver.
Detach the battery cable from the motherboard using a pair of tweezers.
Unhinge the fan cable using your fingers or a pair of tweezers.
Remove the battery from its slot.
Use a Phillips #0 screwdriver to remove the six 2 mm fan screws.
Use a Phillips #0 screwdriver to remove the five 2 mm heatsink screws.
Warped Screw
Disconnect white and black antennae cables.
Disconnect fan cables pulling outwards as shown.
Carefully lift heatsink upward using a Ifixit opening tool or Fingers pull fan out from under the heat sink.
Disconnect the white ribbon cable from the connection lever using a Jimmy.
Using the Jimmy, lift the hard drive out of its slot.
Remove the single 2 mm screw from the SSD with a Phillips #0 screwdriver.
Use a Phillips #0 screwdriver to remove the four 2 mm screws that secure the motherboard.
Using a Jimmy, pull up on power cable
Using the Jimmy, lift up on both ribbon cable clamps, releasing the connection point, just like in step 8.
