Laptops may need a fan replacement to address overheating, noise, reduced performance, frequent shutdowns, error messages, physical damage. It's essential to use compatible replacement fans and follow proper installation procedures for optimal functionality.
Remove ten 2 mm screws using a Phillips #0 screwdriver.
Remove the screw in the center using a T4 Torx screwdriver.
Use an iFixit opening tool to pry open the back panel.
Use a Phillips #0 screwdriver to remove the six 2 mm fan screws.
Use a Phillips #0 screwdriver to remove the five 2 mm heatsink screws.
Warped Screw
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect white and black antennae cables.
Disconnect fan cables pulling outwards as shown.
Carefully lift heatsink upward using a Ifixit opening tool or Fingers pull fan out from under the heat sink.
