ASUS Q405U Hard Drive Replacement
  1. ASUS Q405U Hard Drive Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
  2. ASUS Q405U Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
  3. ASUS Q405U Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Q405U Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Q405U Hard Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
  4. ASUS Q405U Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Q405U Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • OPTIONAL: Additional pictures to demonstrate moving keyboard out of the way without detaching connections.
    • Lift the ribbon cable with gentle pressure, pry the ribbon away from the motherboard on the right side, then the left, then the center, prying away only a little triangle of tape at a time, applying gentle upward pressure to the tape while you loosen and pry.
    • Once you have enough slack in the three ribbons that hold the keyboard down too tightly, lift the front of the keyboard and twist counterclockwise to produce enough room to reach the screws securing the hard drive with your screwdriver.
  5. ASUS Q405U Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the narrow strip of tape to the left of the hard drive.
    • Remove the five screws holding the caddy in.
    • Lift the hard drive slight;y and slide it to the right to remove it from its socket.
Jeremiah Baselice
crwdns2935283:010/25/21crwdne2935283:0
569 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 crwdns2935289:0UMass Dartmouth, Team 2-8, Sinclaire Fall 2021crwdne2935289:0
UMASSD-SINCLAIRE-F21S2G8
crwdns2942667:0crwdne2942667:0 1,115
