Using the plastic opening tools, insert it into the edge and pry open.
Use hands to help pull the back off from the front if needed.
Locate CON2002
Check water indicator on USB Charging Port
Locate and remove three Phillips screws
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to disconnect E893821
Does anyone have any idea where a replacement USB port can be found. Mine isnt water damaged but rather one of the pins broke off and its hanging out of the cable. Now the phone will not charge.
