ASUS PadFone X Rear Facing Camera Replacement
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the camera has been pulled out, replace the old camera with a new camera.
nestor
crwdns2935283:010/07/14crwdne2935283:0
USF Tampa, Team 8-4, Leahy Fall 2014 crwdns2935289:0USF Tampa, Team 8-4, Leahy Fall 2014crwdne2935289:0
USFT-LEAHY-F14S8G4
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 617
