ASUS N550JK-DS71T Laptop RAM stick Replacement
  1. ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. ASUS N550JK-DS71T Laptop RAM stick Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS N550JK-DS71T Laptop RAM stick Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4mm JIS #0 screws from the battery.
  4. ASUS N550JK-DS71T Laptop RAM stick Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS N550JK-DS71T Laptop RAM stick Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using both hands, lift the battery vertically out of the device.
  5. ASUS N550JK-DS71T Laptop RAM stick Replacement, RAM Stick: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put on anti-static wristband and attach clip-end to any metal screw insert.
    • The wristband is recommended when working closely with circuit boards due to potential static discharge.
  6. ASUS N550JK-DS71T Laptop RAM stick Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS N550JK-DS71T Laptop RAM stick Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS N550JK-DS71T Laptop RAM stick Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The RAM will be secured by two metal clips surrounded by white plastic.
    • Spread the metal clips and the RAM stick will pop up. Then gently remove the RAM stick.
Steven Hahn
crwdns2935283:001/29/18crwdne2935283:0
890 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S5-G1, Passmore Spring 2018 crwdns2935289:0USF Tampa, Team S5-G1, Passmore Spring 2018crwdne2935289:0
USFT-PASSMORE-S18S5G1
crwdns2942667:0crwdne2942667:0 1,303
