ASUS MeMo Pad FHD10 Headphone Jack Replacement
  1. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS MeMo Pad FHD10 Headphone Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
  5. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three screws using a Phillips #00 screwdriver.
  6. ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The two speakers are located on opposite sides of the device. Both are long black pieces with connections to the motherboard.
    • Unplug the speaker cables from their connections on the motherboard gently by using tweezers.
  7. ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently use your hands to remove the speakers.
  8. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws using a Phillips #00 screwdriver.
  9. ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully disconnect the cord that connects the on/off button to the motherboard
    • Peel back the electrical tape holding the connections of the motherboard down to the frame of the device.
  10. ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your hands to remove the motherboard from the device.
  11. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Headphone Jack: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS MeMo Pad FHD10 Headphone Jack Replacement, Headphone Jack: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Desoldering Pump
    $3.99
    • Using a soldering gun, desolder the headphone jack from the motherboard at each connection to the motherboard.
    • If you have never used a soldering gun before, check out iFixit's guide for soldering and desoldering.
  12. ASUS MeMo Pad FHD10 Headphone Jack Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently, disconnect the headphone jack.
    • Allow the soldering to cool off before disconnecting.
Dmitry
crwdns2935283:001/21/15crwdne2935283:0
391 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-5, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 9-5, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S9G5
crwdns2942667:0crwdne2942667:0 1,501
