crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0ASUS MB169B Portable Monitorcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. ASUS MB169B Portable Monitor Teardown, Remove Faceplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS MB169B Portable Monitor Teardown, Remove Faceplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS MB169B Portable Monitor Teardown, Remove Faceplate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In this guide you will be disassembling the ASUS portable monitor. Read Ahead and follow the directions to avoid damaging the display or clips holding it in place.
    • There are plastic clips that hold the cover in place. With a spudger insert the edge of the spudger between the faceplate and the rear cover of the monitor, as shown in the picture.
    • Slowly pry up on the faceplate starting at a corner and slowly prying along the outside edge of the faceplate and continuing around the entire cover.
  2. ASUS MB169B Portable Monitor Teardown, Remove LCD: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS MB169B Portable Monitor Teardown, Remove LCD: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS MB169B Portable Monitor Teardown, Remove LCD: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the cover away from the LCD and set off to the side.
    • Remove the 4 screws holding the LCD to the back cover.
    • Do not attempt to remove the display at this time, as it is attached to the main board.
    • Turn the display over, you will see a cable connector attached to the display with yellow tape.
    • Pull up on the yellow tape to flip up the retaining bar holding the connector in place.
    • Pull the connector straight out away from the display.
  3. ASUS MB169B Portable Monitor Teardown, Remove Main Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS MB169B Portable Monitor Teardown, Remove Main Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS MB169B Portable Monitor Teardown, Remove Main Board: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws holding the mainpower board to the rear cover.
    • Starting at a corner use a spudger to gently pry up the main board. Work the spudger around the edges of the main board until it lifts easily.
    • Before completely removing the main board, lift up on the grey tape holding down the wires and pull it away from the back cover.
    • *Optional* You can also disconnect the wire harness if necessary, the process is the same as in Step 2.
  4. ASUS MB169B Portable Monitor Teardown, Complete: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS MB169B Portable Monitor Teardown, Complete: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This concludes the disassembly, if you wanted to replace the LCD, there are two screws connecting the board on the monitor and a wire harness.
    • You would remove these two screws and disconnect the smaller wire harness at the bottom of the LCD and then attach the board on the new LCD.
    • To reassemble, follow these steps in reverse.
  5. ASUS MB169B Portable Monitor Teardown, Additional insight: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • My LCD was dropped and the power connector lifted from the main board, I used a soldering iron to resolder the connector to the board.
    • However, this did not fix the problem because the pins inside the connector were damaged. Instead of trying to resolder a new connector, I found a main board on ebay that I will use to replace it.
Brandon Adair
crwdns2935283:010/28/20crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
what is search word to get the right board at ebay
ebunoha chukwudi - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 3,049
