ASUS K50IJ Screen replacement 15.6" Replacement
crwdns2869540:0crwdne2869540:0: 1,9K
2
20
88
1.885
crwdns2955950:0crwdne2955950:0: 7
crwdns2960004:04crwdne2960004:0, crwdns2960008:03crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
Sometimes screens stop working. This guide will show you how to replace your screen and get back to browsing.
    1. ASUS K50IJ Screen replacement 15.6" Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
    2. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the exposed lip and remove the battery cover.
    3. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Press the tabs on the battery and lift them. The battery should come out easily.
    1. ASUS K50IJ Screen replacement 15.6" Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement, Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement, Fan: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
    2. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the one .5 mm screw located in the top right corner of the battery compartment.
    3. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
    4. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unplug the wire cable attached to the fan by pulling it out .
    5. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
      • Lift the fan up with your fingers.
    1. ASUS K50IJ Screen replacement 15.6" Replacement, Charging Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
    2. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the PH1 screwdriver, remove the four .75 mm screws from the copper heat sync. They will be labeled 1-4.
      • Pull the copper heat sync out of the laptop.
    3. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH1 screwdriver, remove four .75 mm screws from the driver, located in the bottom-right corner of the laptop.
    4. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull on the black tab on the driver to slide the driver back, and lift the driver out of the laptop.
    5. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the PH1 screwdriver, remove the five .5 mm screws from the SD card reader, located in the bottom-middle corner of the laptop.
      • Slide the SD card reader away and out.
    6. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Detach the white and black wires from the Wi-Fi card, located in the central area of the laptop.
    7. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the PH 1 screwdriver, remove the two .25 mm screws from the Wi-Fi card.
    8. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the Wi-Fi card out of its slot to remove.
    9. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH1mm screwdriver, remove one .5 mm screw from the disk drive, located inthe top-right corner of the laptop.
    10. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the disc drive out of its slot.
    11. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH 1 screwdriver, remove the two .5 mm screws from the RAM drive.
    12. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide and lift the RAMdrive out of its port.
    13. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH1 screwdriver, remove the .75 mm screw from the plastic housing corner, located in the bottom-right corner of the laptop.
    14. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unplug the black cable from the central area of the laptop.
    15. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unplug the wire cable in the central area of the laptop.
    16. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unplug the wire and black cables on the motherboard, located in the upper-left corner of the laptop.
    17. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH1 screwdriver, unscrew the two .75 mm screws from the top-left corner of the motherboard.
    18. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH 1 screwdriver, remove the .75 cm screw from the top-middle section of the motherboard.
    19. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH1 screwdriver, remove the .75 mm screw from the top-middle corner of the motherboard.
    20. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH1 screwdriver, remove the three .75 mm screws from the bottom corner of the motherboard.
    21. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • There is a ribbon cable connected to the back of the motherboard. Be careful not to break the ribbon cable.
      • Slide the motherboard to the right and lift it up, but do not pull it completely out.
    22. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently unplug the ribbon cable from the underside of the motherboard.
    23. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The ribbon cable that was plugged into the motherboard is attached to the keyboard. Be sure not to damage it.
      • Use the metal spudger or opening tool across the top edge of the keyboard to pop it out.
    24. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the metal spudger or opening tool to pop out the plastic hinge covers.
    25. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the PH1 screwdriver to remove the .75 mm screws from the hinges. Each hinge has one screw.
    26. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be careful not to damage the cables that are attached to the screen frame. Be sure to pull them through the laptop carefully.
      • The screen should separate from the rest of the laptop.
    27. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH1 screwdriver, remove the .75 mm screw from the bottom-middle section was previously covering.
    28. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH 1 screwdriver, remove the .75 cm screw from the bottom-middle section where the keyboard was previously covering.
    29. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the front cover off of the laptop.
    30. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the laptop back over. The charging port will be located in the top-right corner.
    1. ASUS K50IJ Screen replacement 15.6" Replacement, Screen replacement 15.6": crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement, Screen replacement 15.6": crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a metal spudger, pop off the six rubber screw covers.
    2. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the PH1mm screwdriver, remove the six .75 mm screws from the front of the screen frame.
    3. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the plastic opening tool or spudger along the edge of the frame, to pry off the frame.
    4. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the PH1 screwdriver, remove the four bottom .75 mm screws from the screen frame.
    5. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the PH1 screwdriver, remove the two .75 cm screws from the top of the screen frame.
    6. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the bracket off the top of the screen frame.
    7. ASUS K50IJ Screen replacement 15.6" Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the screen should out.
Dmitriy Ivakhnenko
crwdns2935283:009/27/17crwdne2935283:0
113 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G3, Carnegie Fall 2017 crwdns2935289:0Eastern Washington University, Team S1-G3, Carnegie Fall 2017crwdne2935289:0
EWU-CARNEGIE-F17S1G3
Now, I don´t know how to connect the cables to the motherboard because they are too short.
tatiana.morais.89 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 88
crwdns2959996:0crwdne2959996:0 1,885
