ASUS FonePad 7 Vetro/Touch Replacement
  1. ASUS FonePad 7 Vetro/Touch Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
  2. ASUS FonePad 7 Vetro/Touch Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove adesive strips.
    • Disconnect the battery connectors by carefully pulling down on them using a spudger or plastic opening tool.
  3. ASUS FonePad 7 Vetro/Touch Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect Touch Connectors using a spudger or plastic opener tool.
    • Disconnect the ZIF connectors holding the battery.
    • You can also use your hand to remove ZIF connectors.
    • ZIF connectors are delicate so be careful when you are removing them.
  4. ASUS FonePad 7 Vetro/Touch Replacement, Remove Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
  5. ASUS FonePad 7 Vetro/Touch Replacement, Power Management: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Power Management: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect cable
    • Remove the two Philips #0 screws from the power management board
    • Remove Philips #0 screw
  6. ASUS FonePad 7 Vetro/Touch Replacement, MotherBoard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, MotherBoard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove GPS antenna with a spudger.
    • Disconnect the connector
  7. ASUS FonePad 7 Vetro/Touch Replacement, Power and Volume Buttons: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Power and Volume Buttons: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Power and Volume Buttons: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the power and volume connector
  8. ASUS FonePad 7 Vetro/Touch Replacement, Earpiece: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Earpiece: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect Earpiece connector
  9. ASUS FonePad 7 Vetro/Touch Replacement, Display Cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Display Cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Display connector from motherboard.
  10. ASUS FonePad 7 Vetro/Touch Replacement, MotherBoard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4screw Philips #0 from motherboard
  11. ASUS FonePad 7 Vetro/Touch Replacement, Components: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Components: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Components: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove Components
  12. ASUS FonePad 7 Vetro/Touch Replacement, Remove Glass (TouchScreen): crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS FonePad 7 Vetro/Touch Replacement, Remove Glass (TouchScreen): crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inserisci qui la competenza.
  13. ASUS FonePad 7 Vetro/Touch Replacement, Replace with new Glass. Good Job ;): crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
Per rimontare il dispositivo, segui queste istruzioni in ordine inverso.
Andrew
crwdns2935283:002/17/15crwdne2935283:0
141 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 3,473
