This guide will explain the process of installing a new battery, or replacing an existing one. The ASUS F555UA-EH71 comes with a 14.8V 38Wh Li-ion battery.
Remove the ten 18 mm screws holding down the outer shell of the laptop using the Phillips #000 screwdriver.
Use your fingers to gently pry open the gap between the silver and black parts of the casing.
Separate the keyboard panel from the body of the laptop by wedging the iFixit Opening Tool in between the keyboard panel and the body.
Gently open the casing until the white, silver, and gold power strips are visible. Gently peel the strips from the bottom side of the laptop.
Disconnect the two cables connecting the keyboard panel to the laptop.
Remove the keyboard panel from the laptop.
Use the Phillips #000 screwdriver to remove the eight 4 mm screws holding the battery in place.
Carefully remove the battery from the device.
