ASUS F550 RAM Replacement
crwdns2869540:0crwdne2869540:0: 5.5K
2
22
96
5,538
crwdns2955950:0crwdne2955950:0: 3
crwdns2960008:03crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:030crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
    1. ASUS F550 RAM Replacement, ASUS F550 HDD/Ram Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS F550 RAM Replacement, ASUS F550 HDD/Ram Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the battery, using release clips.
      • Ensure device has no residual power by attempting boot once battery is removed.
      • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
      • Remove HDD and RAM cover
    1. ASUS F550 RAM Replacement, Remove Ram: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS F550 RAM Replacement, Remove Ram: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Release securing arms and remove RAM.
Ryan
crwdns2935283:008/19/15crwdne2935283:0
1,519 crwdns2915208:0crwdne2915208:0
Pretty sure only 2 of the 4 screws need to be removed.
tobiaskuhn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Can confirm only two screws required removal to enable access on my model F550C
Have successfully replaced HD once, but had slight issue getting it recognised
which is more of a BIOS issue, helps if you have a seperate bootable USB drive
but once recognised and OS installed, have several times swapped between the two
HDs (one Win8, one Linux - eventually plan to only use linux on this system).
Regards
Mike.
mihaly_k - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yes only two need to be removed, however I initially wrote a tear down to gain access to the network card etc and the way ifix it is structured for guide creation these steps are in fact used in that longer guide. I've amended the instructions now so hopefully they are more clear now.
Ryan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 96
crwdns2959996:0crwdne2959996:0 5,538
