ASUS Eee PC 1008ha Battery Replacement
  1. ASUS Eee PC 1008ha Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. ASUS Eee PC 1008ha Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Eee PC 1008ha Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Eee PC 1008ha Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. ASUS Eee PC 1008ha Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Eee PC 1008ha Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
Alex Powers
crwdns2935283:004/17/13crwdne2935283:0
Cal Poly, Team 21-52, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 21-52, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S21G52
crwdns2935297:011crwdne2935297:0
where could i find compatible batteries?
qforkyu - crwdns2934203:0crwdne2934203:0
Good question! Did you find one?
paulteale -
This guide is misleading. There is no way to do step 1 just from the front. At least I cannot do it and my notebook is already half open due to the swollen battery. Most guides show that you need to disassemble the whole thing.
For instance:
http://forum.notebookreview.com/asus/388...
cis - crwdns2934203:0crwdne2934203:0
Батарея состоит из трёх отдельных Li-ion аккумуляторов, соединённых через плату контроллера. Обычно вздувается один из трёх аккумуляторов. Надо разобрать ваш нетбук, как показано в видео:
https://www.youtube.com/watch?v=-3ipeduI...
Тогда надо её аккуратно выкусить и стараться не проколоть надутую батарею, потому что в ней много неприятного запаха. На её место можно поставить подходящий по толщине аккумулятор с напряжением 3.6 - 3.7V с током до 1000mA (1A) и обязательно соблюдать полярность при установке аккумулятора. Тогда вам будет счастье.
С уважением, устный переводчик синхронист.
Simultaneous Translation - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 10,446
