ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement
    1. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the laptop over, you should see two battery tabs.
      • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
    2. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • While holding the left tab towards the left. Gently slide the battery out of the laptop.
    1. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement, SSD: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement, SSD: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement, SSD: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 2.5mm Phillips #1 screws.
      • Gently remove back panel by lifting the tab. This will expose the SSD.
    2. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the two 2.0mm Phillips #0 screws.
    3. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The SSD should now pop up.
      • Grasping the sides of the SSD, gently pull it out at the angle it makes with the device.
mir
crwdns2935283:003/24/17crwdne2935283:0
409 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 crwdns2935289:0UMass Dartmouth, Team S2-G8, Isaacson Spring 2017crwdne2935289:0
UMASSD-ISAACSON-S17S2G8
crwdns2935297:025crwdne2935297:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 5,674
