ASUS E210MA-TB.CL464BK Battery Replacement
  1. ASUS E210MA-TB.CL464BK Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the laptop with the bottom side facing up. Have the front (where the mousepad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 JIS screwdriver.
  2. ASUS E210MA-TB.CL464BK Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS E210MA-TB.CL464BK Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 mm screws around the USB port.
  4. ASUS E210MA-TB.CL464BK Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS E210MA-TB.CL464BK Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 mm screws around the battery.
    • Carefully lift up the USB port and set it to the side.
  5. ASUS E210MA-TB.CL464BK Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS E210MA-TB.CL464BK Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the connection between the motherboard and the battery by pulling towards the speaker side.
    • Repeat the same process to remove the blue tape on the second picture.
  6. ASUS E210MA-TB.CL464BK Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and remove the battery.
John Hutchins
crwdns2935283:002/07/23crwdne2935283:0
763 crwdns2915208:0crwdne2915208:0
Gateway, Team 73-6, Gonzalez Spring 2023 crwdns2935289:0Gateway, Team 73-6, Gonzalez Spring 2023crwdne2935289:0
GCC-GONZALEZ-S23S73G6
crwdns2942667:0crwdne2942667:0 959
