If your keyboard has stopped working or if you need to get inside of your laptop for other repairs, use this guide to remove the keyboard. Removing the keyboard is the first step to disassembling your laptop and the primary prerequisite for all tasks.
Use a Philips #1 screwdriver to remove the nine screws from the back cover.
Turn the laptop over and open the display.
Insert the flat edge of the spudger into the crease of the keyboard cover.
While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
Slowly lift the cover open from the front of the laptop, but do not completely remove it.
Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
I need assistance. When I opened the cover, exposing the keyboard and main board I pulled the 3 blue and white data cables from the main board. How can I repair this? Someone please help!!!!!!
Disconnect the three data cables from the motherboard.
Remove the fully disconnected keyboard module from the laptop.
No need to remove the keyboard. The ribbons are plenty long to give slack and allow access.
Good overall, thank you!
Does anybody knows how to remove the keyboard from the keyboard module??I want to replace the keyboard not the whole piece
where can I get a keyboard replacement
Replacement Keyboard N2840 s/n EBNOCX62041047D sold by, Alpha Vr Electronics, 860-755-2309 ext. 22831 $20.99
