ASUS Chromebox 4 SSD / Memory Replacement
  1. ASUS Chromebox 4 SSD / Memory Replacement, Create a recovery USB: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Especially if you are replacing the SSD, you will need the recovery USB to reinstall ChromeOS on the new SSD, or the Chromebox won't boot.
    • Follow the instructions from Google's website to create a recovery USB stick: https://support.google.com/chromeosflex/...
    • You will need an USB stick with at least 8GB of capacity (the contents of the stick will be overwritten!) and a system running the Chrome browser - so it's easiest to do it on the Chromebox before taking it apart for an upgrade.
  2. ASUS Chromebox 4 SSD / Memory Replacement, Remove the feet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the feet of the device. They are glued on using soft glue and should come off easily.
  3. ASUS Chromebox 4 SSD / Memory Replacement, Remove the screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 screws you uncovered by removing the feet.
  4. ASUS Chromebox 4 SSD / Memory Replacement, Remove the top: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the top. Take care of the connector cable that links the power input socket with the motherboard.
  5. ASUS Chromebox 4 SSD / Memory Replacement, Update RAM/SSD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can update the SSD by removing two screws (the WiFi card needs to be removed first).
    • To test the machine without putting it back together, you can use an USB-C laptop charger to power it temporarily.
    • If you replaced the SSD, you will have to use the recovery USB created on the first step to restore the operating system.
Wooing Snowdrift
crwdns2935283:007/30/23crwdne2935283:0
370 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 503
