Use this guide to replace the display on your device.
Flip open the Chromebook as shown. Using the plastic opening tool, gently pry open the hinge cover of the display. Once it snaps off, remove the hinge cover.
Continue to use the plastic spudger to gently pry the front frame from the display. It will come off with a snap.
Using the JIS J000 Screwdriver, unscrew and remove the (4) four 3mm screws from the display.
Gently peel back the tape to remove the display.
