ASUS Chromebook C200MA DS01 USB Board Replacement
  1. ASUS Chromebook C200MA DS01 USB Board Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 USB Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 USB Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the USB board ZIF (zero insertion force) connectors which connect the motherboard to the USB board in the upper left.
    • Flip the ZIF retaining flaps up using a plastic opening tool or your fingers.
    • Pull gently on the ribbon cable to disconnect it from the sockets.
  6. ASUS Chromebook C200MA DS01 USB Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 5.77 mm Phillips screws on the USB board.
    • Remove the two 4.77 mm Phillips screws from the hinge.
  7. ASUS Chromebook C200MA DS01 USB Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to lift the hinge from the Chromebook.
  8. ASUS Chromebook C200MA DS01 USB Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the USB board from the Chromebook.
Christopher Lim
crwdns2935283:004/26/17crwdne2935283:0
779 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S23-G4, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S23-G4, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S23G4
crwdns2935297:019crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 632
