This guide will take you through a step-by-step process for the removal of your Chromebook’s USB board.
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
Remove the back panel by lifting it away from the Chromebook.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Disconnect the USB board ZIF (zero insertion force) connectors which connect the motherboard to the USB board in the upper left.
Flip the ZIF retaining flaps up using a plastic opening tool or your fingers.
Pull gently on the ribbon cable to disconnect it from the sockets.
Remove the three 5.77 mm Phillips screws on the USB board.
Remove the two 4.77 mm Phillips screws from the hinge.
Use a plastic opening tool to lift the hinge from the Chromebook.
Gently lift the USB board from the Chromebook.
