This guide will take you through a step-by-step process for the removal of your Chromebook’s touch pad.
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
Remove the back panel by lifting it away from the Chromebook.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
Locate the touchpad.
Locate the touch pad cable connector.
Disconnect the touch pad ZIF(zero insertion force) connector.
Flip the flap up using a spudger or your fingers.
Pull gently on the ribbon cable to disconnect.
Gently remove the adhesive on the touch pad ribbon cable.
Gently remove the metallic tape from the touch pad only.
Remove the three 1.8 mm Phillips #00 screws.
Lift the far edge of the touch pad to remove it.
