This replacement guide will show you how to access and remove the battery in your Chromebook.
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
Remove the back panel by lifting it away from the Chromebook.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
