Details to remove the volume control of ASUS Chromebook Flip C100PA-RBRKT07
Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
Use the iFixit opening tool to remove the back of the laptop.
Use the blunt nose tweezers to separate the keyboard from the internal components.
Use the tweezers to remove the white cable from the volume control component.
Remove the two 1.2 mm screws using the J00 size screwdriver.
Grip the component using the tweezers and lift it out of the device.
