APS Tech 101629 Exhaust Fan Replacement
  1. APS Tech 101629 Exhaust Fan Replacement, External Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement, External Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement, External Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Exhaust Fan Replacement, Channel Switch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement, Channel Switch: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
  8. APS Tech 101629 Exhaust Fan Replacement, Power Switch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement, Power Switch: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Depress 2 pressure holds on each side of the power switch.
    • Press out the back of the device.
  9. APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all four 4 connections from the power switch.
    • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
    • These are very hard to get off, use patience and wiggling.
  10. APS Tech 101629 Exhaust Fan Replacement, Exhaust Fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove temperature guage.
  11. APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 APS Tech 101629 Exhaust Fan Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the exhaust fan out of the way so you can access its control cord.
    • Use the spudger to depress the hold on the fan cord.
    • Gently pull fan cord from connection and remove fan completely.
Patrick Meyer
crwdns2935283:004/10/11crwdne2935283:0
83 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-60, Amido Spring 2011 crwdns2935289:0Cal Poly, Team 24-60, Amido Spring 2011crwdne2935289:0
CPSU-AMIDO-S11S24G60
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 751
