APS Tech 101629 Channel Switch Replacement
  1. APS Tech 101629 Channel Switch Replacement, External Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 APS Tech 101629 Channel Switch Replacement, External Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 APS Tech 101629 Channel Switch Replacement, External Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Channel Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APS Tech 101629 Channel Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Channel Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APS Tech 101629 Channel Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Channel Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Channel Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APS Tech 101629 Channel Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Channel Switch Replacement, Channel Switch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APS Tech 101629 Channel Switch Replacement, Channel Switch: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Channel Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 APS Tech 101629 Channel Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 APS Tech 101629 Channel Switch Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
Alexis Weckel
crwdns2935283:004/11/11crwdne2935283:0
140 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-60, Amido Spring 2011 crwdns2935289:0Cal Poly, Team 24-60, Amido Spring 2011crwdne2935289:0
CPSU-AMIDO-S11S24G60
crwdns2942667:0crwdne2942667:0 796
