APEX TM785CH Front Camera Replacement
  1. APEX TM785CH Front Camera Replacement, Back Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APEX TM785CH Front Camera Replacement, Back Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Front Camera Replacement, Front Camera: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APEX TM785CH Front Camera Replacement, Front Camera: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To get to the front camera, you will first need to remove the top panel.
    • Unscrew two 2.25 mm Phillips screws with a #00 screwdriver from the top plastic panel to remove it.
  3. APEX TM785CH Front Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once unscrewed, use a spudger to pop the panel off by wedging it underneath the panel.
  4. APEX TM785CH Front Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 APEX TM785CH Front Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 APEX TM785CH Front Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, use plastic coated tweezers to pull up the black release tab.
    • Pull on the black connector with tweezers as close as possible to the white connector base, making sure not to pull on the connector base.
    • It is important to be careful not to damage the black connector tape or the white base.
    • Next, use the tweezers to peel off the tape holding down the connector to the front camera.
    • The front camera can now be removed from its socket.
Brian Graschel
crwdns2935283:003/23/15crwdne2935283:0
823 crwdns2915208:0crwdne2915208:0
Baylor, Team 4-1, Williams Spring 2015 crwdns2935289:0Baylor, Team 4-1, Williams Spring 2015crwdne2935289:0
BU-WILLIAMS-S15S4G1
crwdns2942667:0crwdne2942667:0 325
