APEX AP-GS918 Battery Replacement
  1. APEX AP-GS918 Battery Replacement, Power/Volume Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 APEX AP-GS918 Battery Replacement, Power/Volume Button: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 APEX AP-GS918 Battery Replacement, Power/Volume Button: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 APEX AP-GS918 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 APEX AP-GS918 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APEX AP-GS918 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
  4. APEX AP-GS918 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APEX AP-GS918 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin removing the black tape covering the motherboard inside the tablet.
  5. APEX AP-GS918 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
  6. APEX AP-GS918 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APEX AP-GS918 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
Megan Lozicki
crwdns2935283:002/19/15crwdne2935283:0
416 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-1, Leahy Winter 2015 crwdns2935289:0USF Tampa, Team 9-1, Leahy Winter 2015crwdne2935289:0
USFT-LEAHY-W15S9G1
bien consejo, creo que es sencillo por todos para seguin estos pasos
harkhoscole - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 541
