APC Back-UPS 450 battery Replacement
  1. APC Back-UPS 450 battery Replacement, Turn OFF and UNPLUG UPS: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 APC Back-UPS 450 battery Replacement, Turn OFF and UNPLUG UPS: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 APC Back-UPS 450 battery Replacement, Turn OFF and UNPLUG UPS: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off and unplug your UPS from wall power, then turn it upside down.
    • Pull the yellow tab loose, to disconnect the battery.
  2. APC Back-UPS 450 battery Replacement, Open case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 APC Back-UPS 450 battery Replacement, Open case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 APC Back-UPS 450 battery Replacement, Open case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a long number 1 Phillips screwdriver to remove 4 screws so you can open the case.
    • This may be difficult to find an appropriate screwdriver. You will also possibly need to gently pry between the two pieces of the case with a small flathead screwdriver to separate the two pieces of the case.
  3. APC Back-UPS 450 battery Replacement, Disconnect, remove old battery, & install new: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APC Back-UPS 450 battery Replacement, Disconnect, remove old battery, & install new: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect and remove the battery from the case.
    • Install the new battery and connect it, noting the red and black color coating.
  4. APC Back-UPS 450 battery Replacement, Reassemble and test: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassembly is the reverse of removal.
Lance Wessel
crwdns2935283:008/31/10crwdne2935283:0
530 crwdns2915208:0crwdne2915208:0
Use a #1;phillips head screwdriver.
I own an APC RN450M. A #2:phillips head screwdriver doesn't work with that 450 VA model. In fact it doesn't even fit in the screw holes.
But a #1;phliips head screwdriver with at least an 8 inch shaft woks fine.
Bob Hyman - crwdns2934203:0crwdne2934203:0
Agreed with @bobhyman, a #1 Phillips screwdriver is what's needed, although something a little shorter than 8 inches is probably OK too (measure the height of the entire unit as an upper bound). It might not be super-easy to find one of these at a local hardware store, but I ended up ordering something on Amazon. Other than that this is a pretty easy replacement. Thanks!
bmah - crwdns2934203:0crwdne2934203:0
I used a #2, but it was a skinny one.
The yellow battery shutoff clip is what gave me the most problem, it was really tight in there!
Crissa Kentavr - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 39
crwdns2936753:07crwdne2936753:0 149
crwdns2936753:030crwdne2936753:0 572
crwdns2942667:0crwdne2942667:0 12,097
