AIAIAI Repair guide: UNIT-4 Tweeter
    • All you need is a thin, hard plastic tool or an old credit card and 2 cross head screwdrivers. We use a Phillips 00 and a Phillips 2.
    • Make sure UNIT-4 is turned off.
    • Use a thin, hard plastic tool or an old credit card and pull off the front panel.
    • Take a screwdriver and remove all 16 screws as shown on the image below.
    • Place UNIT-4 upright and carefully lean forward while supporting the front as shown in the video.
    • If the front housing is too tight, we recommend using a flathead screwdriver or similar to pull the housing out. You can do this by pulling it out by the magnet locks.
    • Use a thin and pointy tool to unlock the cable connectors.
    • Unscrew the 3 screws
    • Carefully insert the new tweeter.
    • Connect the cable connectors.
    • Screw in the 3 screws.
AIAIAI - Albert
crwdns2935283:011/27/24crwdne2935283:0
913 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 38
