AEE Mach 1 Motherboard Replacement
  1. AEE Mach 1 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the AEE Mach 1 and place it on a flat surface with its propellers facing up.
  2. AEE Mach 1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AEE Mach 1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Holding the base of each propeller still, unscrew the propeller clockwise for each arm.
  3. AEE Mach 1 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the drone so that the bottom of the AEE Mach 1 is facing up.
  4. AEE Mach 1 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws on the drone's arms using a Torx T5 screwdriver.
  5. AEE Mach 1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry open the top panel of the drone using a spudger.
    • Do not completely remove the panel, as there will still be wired connections between the two halves.
  6. AEE Mach 1 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out and set aside the battery pack, located on the back of the AEE Mach 1.
  7. AEE Mach 1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the top panel slightly to reveal the four screws beneath each propellor arm.
    • Remove each of the four screws with a Phillips #0 screwdriver.
    • Lift off the top panel, as it should now be free from the rest of the device.
  8. AEE Mach 1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AEE Mach 1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws from each corner of the motherboard with a Phillips #00 screwdriver.
  9. AEE Mach 1 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AEE Mach 1 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger to gently remove the copper tape from the mother board.
  10. AEE Mach 1 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peeling up the copper tape will expose another metal chip that has wires that are soldered to the mother board.
    • Remove the four screws holding the secondary board in place using a Phillips #00 screwdriver.
  11. AEE Mach 1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AEE Mach 1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AEE Mach 1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ZIF connector joining the motherboard and secondary board by prying up the locking black tab and pulling out the cable with some blunt nosed tweezers.
    • Desolder the red and black wires joining the two boards.
    • For help soldering, check out our How To Solder and Desolder Connections guide.
  12. AEE Mach 1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard by lifting it from the case.
Jake Kenison
crwdns2935283:009/16/20crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G7, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G7, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S1G7
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 732
