ACN Iris WG4K Video Screen Ribbon Cable Replacement
  1. ACN Iris WG4K Video Screen Ribbon Cable Replacement, Handset: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ACN Iris WG4K Video Screen Ribbon Cable Replacement, Handset: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Video Screen Ribbon Cable Replacement, Lower Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Video Screen Ribbon Cable Replacement, Blade Connector: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  8. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up on the upper case to separate it from the keypad/speaker panel.
  9. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (5 mm) located on the upper case.
  10. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the top case 180 degrees so that the video screen is closest to you.
    • Lift up the bottom up so that it is perpendicular to the table (this helps you reach the two top screws).
    • The four Phillips head screws (6 mm) are highlighted by the red circles.
  11. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm).
  12. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the top case so that the video screen is facing up.
  13. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the top case 180 degrees.
    • Gently lift up on the video screen and the blade and ribbon connector to give you more slack to work with.
  14. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the video screen face down to expose the two screws. The screws are indicated by the red circles.
  15. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (6 mm)
  16. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the ribbon connector and blade connector through the top case.
  17. ACN Iris WG4K Video Screen Ribbon Cable Replacement, Video Screen Ribbon Cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note that the video screen is no longer attached to the top case, place in on a flat surface.
    • Gently lift of the silver casing.
  18. ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ACN Iris WG4K Video Screen Ribbon Cable Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The two ribbon connectors are indicated by the red rectangles.
    • Disconnect the two ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull out the ribbon cables. Gently pull out the ribbon cables.
Itze Kenney
crwdns2935283:002/14/17crwdne2935283:0
1,066 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 20-4, Remmell Spring 2017 crwdns2935289:0USF Tampa, Team 20-4, Remmell Spring 2017crwdne2935289:0
USFT-REMMELL-S17S20G4
crwdns2935297:020crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 352
