crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Candle lampcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. A Candle lamp, Get prepare: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The product before teardown
    • From its initial look, it can mainly separate into four parts. The top ( lamp shade) , the stand ( the tube ) , the base and the wire & controller.
    • Overall product dimension : 290 x 185x 150mm . Weight : 585 gram
  2. A Candle lamp, Remove the base cap: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back of the lamp base was pulled off and flipped over revealing the base structure. Here a craft knife was used for the removal.
    • The cap functions as a cover to hide the cable , its material is High-density Polyethylene ( HDPE) and is injection molded.
    • The dimension is 15cm diameter x5mm thickness , its weight is 29g.
  3. A Candle lamp, Cut the lock: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The white lock to secure the wire and it was removed by a grip and a wire cutter
    • The lamp base is a platform for a candle to sit on top, this view is a close up to see where does the cable goes
    • The lamp base is made of mild steel and it’s about 15cm diameter x2.7cm height with 142grams in weight.
  4. A Candle lamp, Remove the Hex nuts: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The hex nut was removed by the spanner.
    • The number 6 spanner was used
  5. A Candle lamp, Remove screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws inside the light bulb connector
    • The screws are machined made and the type of screws is a mushroom-head with 4mm head diameter 10mm tall.
  6. A Candle lamp, Cut the light bulb connector: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the connector head and pull out the cable after removing the nut from both sides
    • The image showed a light bulb connector and its probably a HDPE or Acrylonitrile Butadiene Styrene (ABS) plastic , injection melded , overall dimension is 28mm diameter x 17mm in height
  7. A Candle lamp, Remove the control panel case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the control panel case by unfastening the screw
    • The case functions to protect damages from the circuit board and it’s made by ABS/ HDPE , injection molded with an overall dimension 900mm length x 400 width x10 height, 21gram in weight
  8. A Candle lamp, Pull out cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the cable from the tube
    • The cable jacket is PVC , 1230mm length with 6mm thickness , weigh in 78gram
  9. A Candle lamp, Separate parts: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate parts : the nuts , the lamp stand, the lamp shade , the base, the controller case , the dimmerable knot and the screws
  10. A Candle lamp, Small parts close-up: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here is the small component close-up shot of the diassembly of the candle lamp
  11. A Candle lamp, The product teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finished the product teardown. There are about 14 components of it.
Ut Mio Vu
crwdns2935283:003/27/24crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 201
