8BitDo Ultimate Wireless D-Pad Replacement
crwdns2869540:0crwdne2869540:0: 551
5
35
183
551
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:015crwdne2931287:0
Do you need to replace the D-pad on your 8BitDo Ultimate Wireless? If so, this guide will show you how to correctly and safely do so!
With that said, please make sure to check our Troubleshooting Guides first. Often times, there is no need to go as far as replacing the D-pad entirely.
Before beginning, turn off the controller and ensure it will not accidentally reconnect during the repair.
    1. 8BitDo Ultimate Wireless D-Pad Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 8BitDo Ultimate Wireless D-Pad Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert an opening pick into the seam between the left controller grip and main controller body.
      • Pry the grip off.
      • Repeat for the right grip.
    2. 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    3. 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
      • Set the halves next to each other with care not to strain the connected ribbon cables.
    4. 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The ribbon cable is secured with a locking tab connector.
      • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    1. 8BitDo Ultimate Wireless D-Pad Replacement, D-Pad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 8BitDo Ultimate Wireless D-Pad Replacement, D-Pad: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the seven 5 mm Phillips #00 screws securing the PCB to the top shell, then lift the board out.
    2. 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully lift the D-pad conductive pad out of the shell.
    3. 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 8BitDo Ultimate Wireless D-Pad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the directional pad.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexander Garcia
crwdns2935283:004/03/26crwdne2935283:0
473 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 crwdns2935289:0UMass Dartmouth, Team 1-3, Biswokarma Spring 2026crwdne2935289:0
UMASSD-BISWOKARMA-S26S1G3
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 183
crwdns2959996:0crwdne2959996:0 551
