8BitDo Ultimate Wired Buttons Replacement
  1. 8BitDo Ultimate Wired Buttons Replacement, Buttons: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement, Buttons: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement, Buttons: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the controller such that the back of the controller is facing you.
    • Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
  2. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the other grip panel off using the same method.
  3. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the TR6 Torx Security screwdriver to remove the top left 10.44 mm torx screw on the backside.
    • Use tweezers to help remove the screws (optional).
  4. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the TR6 Torx Security screwdriver to remove the middle left 10.44 mm Torx screw on the backside.
  5. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the TR6 Torx Security screwdriver to remove the bottom left 10.44 mm Torx screw on the backside.
  6. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the TR6 Torx Security screwdriver to remove the top right 10.44 mm Torx screw on the backside.
  7. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the TR6 Torx Security screwdriver to remove the middle right 10.44 mm Torx screw on the backside.
  8. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the TR6 Torx Security screwdriver to unscrew the bottom right 10.44 mm Torx screw on the backside.
  9. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool into the small opening between the front and back panels, and gently pry the back panel away to open the bottom clamps of the top panel of the controller.
  10. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool into the small opening between the front and back panel (top view) and pry away to remove the top half.
    • A ribbon cable connects the front and back portions of the controller.
    An alternative method here is to rotate the front panel upwards, this will release the clasps at the top naturally. Do be careful to not overtension the ribbon cable, and to guide the joysticks through the front panel.
    Zarlin - crwdns2934203:0crwdne2934203:0
  11. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #0 Screwdriver to remove all seven 6.14 mm Phillips screws from the button PCB.
    #1 worked better for me, with #0 I was very close to stripping the screws.
    ruke - crwdns2934203:0crwdne2934203:0
    Phillips #1 is indeed the correct fit, also for the 8BitDo Ultimate Wireless
  12. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the button PCB.
    • Pinch the silicone cover on the buttons to remove it, such that the buttons are exposed.
  13. 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Ultimate Wired Buttons Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Simply using the force from your finger, push the button out of the housing.
    • Pull button out.
crwdns2935229:08crwdne2935229:0
Tanvi Verma
crwdns2935283:002/08/24crwdne2935283:0
752 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 4-3, Harold Spring 2024 crwdns2935289:0University of North Texas, Team 4-3, Harold Spring 2024crwdne2935289:0
UNT-HAROLD-S24S4G3
From where to purchase spare parts, like buttons?
Mitko - crwdns2934203:0crwdne2934203:0
I purchased mine from the official store: https://shop.8bitdo.com/collections/repa...
Zarlin -
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 120
crwdns2942667:0crwdne2942667:0 2,050
