8BitDo SN30 Pro+ Controller Buttons Replacement
  1. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Trigger Buttons: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Trigger Buttons: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Covers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
  8. 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
  9. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the five silicone rubber pads.
    • Three black conductive pads.
    • Two clear pads.
    • During reassembly, make sure AXBY conductive rubber has the cut out on the top.
  10. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the buttons you wish to replace.
    • The Home button is two parts: the center button and the outer clear ring.
crwdns2935229:09crwdne2935229:0
Brian W
crwdns2935283:012/21/11crwdne2935283:0
1.692 crwdns2915208:0crwdne2915208:0
Hi, it looks like the buttons have little notches that limit where they can go. I was really hoping to modify it so that my a button is green and my b is red would that work if I file down that little notch?
Will Platt - crwdns2934203:0crwdne2934203:0
The buttons are all the same height, so feel free to file down. Those nubs are just part of assemble process.
But do leave the 2 longer stems on each side of the button, they stop it from rotating freely.
Brian W -
I just completed this guide, and it is 100% perfection. The photos are useful and clear, and explanations are on point. Many thanks.
Chris Zirker - crwdns2934203:0crwdne2934203:0
I especially appreciate mention of screw length as I'm prone to mixing them up. Lovely guide 🫠
Joshua Napier - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 158
crwdns2942667:0crwdne2942667:0 9,411
