5G mmWave Antenna Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. 5G mmWave Antenna Removal, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5G mmWave Antenna Removal, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. 5G mmWave Antenna Removal, Adhesive information: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Adhesive information: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Adhesive information: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. 5G mmWave Antenna Removal, Apply a suction handle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5G mmWave Antenna Removal, Apply a suction handle: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. 5G mmWave Antenna Removal, Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Insert an opening pick: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. 5G mmWave Antenna Removal, Separate the rear cover adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Separate the rear cover adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Separate the rear cover adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. 5G mmWave Antenna Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. 5G mmWave Antenna Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. 5G mmWave Antenna Removal, Prop up the rear cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Prop up the rear cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Prop up the rear cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. 5G mmWave Antenna Removal, Remove the wireless charging assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5G mmWave Antenna Removal, Remove the wireless charging assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $31.41
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
  10. 5G mmWave Antenna Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
  11. 5G mmWave Antenna Removal, Disconnect the rear cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Disconnect the rear cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Disconnect the rear cover: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
  12. 5G mmWave Antenna Removal, Remove the rear cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
  13. 5G mmWave Antenna Removal, Remove the cable cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5G mmWave Antenna Removal, Remove the cable cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP screwdriver to remove the two screws securing the cable cover:
    • One 2.3 mm‑long screw
    • One 5.4 mm‑long screw
  14. 5G mmWave Antenna Removal: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5G mmWave Antenna Removal: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to remove the cable cover.
  15. 5G mmWave Antenna Removal, Disconnect the battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Disconnect the battery: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Disconnect the battery: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
  16. 5G mmWave Antenna Removal, Remove the 5G mmWave cover screw: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5G mmWave Antenna Removal, Remove the 5G mmWave cover screw: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP screwdriver to remove the 5.4 mm‑long screw securing the mmWave antenna cover.
  17. 5G mmWave Antenna Removal, Unclip the 5G mmWave cover: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Unclip the 5G mmWave cover: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Unclip the 5G mmWave cover: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger under the clip near the bottom left corner of the mmWave antenna cover and pry up to unclip it.
  18. 5G mmWave Antenna Removal, Remove the 5G mmWave cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5G mmWave Antenna Removal, Remove the 5G mmWave cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
  19. 5G mmWave Antenna Removal, Disconnect the 5G mmWave antenna: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5G mmWave Antenna Removal, Disconnect the 5G mmWave antenna: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
  20. 5G mmWave Antenna Removal, Disconnect the front facing camera: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5G mmWave Antenna Removal, Disconnect the front facing camera: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
  21. 5G mmWave Antenna Removal, Remove the 5G mmWave antenna screw: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Remove the 5G mmWave antenna screw: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5G mmWave Antenna Removal, Remove the 5G mmWave antenna screw: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.3 mm‑long screw securing the mmWave antenna.
  22. 5G mmWave Antenna Removal, Remove the 5G mmWave antenna: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5G mmWave Antenna Removal, Remove the 5G mmWave antenna: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119.190 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.731crwdne2935297:0
crwdns2942667:0crwdne2942667:0 48
