5. Canbus
  1. 5. Canbus, 5. Canbus: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Create the CAN0 interface file
    • sudo nano /etc/network/interfaces.d/can0
    • Enter the following
    • auto can0 iface can0 can static bitrate 500000 up ifconfig $IFACE txqueuelen 256 pre-up ip link set can0 type can bitrate 500000 pre-up ip link set can0 txqueuelen 256
    • You can copy paste into the file but make sure your formatting is correct to include the single space in the beginning of the last 4 lines.
    • Exit and save the file with CTRL + SHIFT X > Yes
    • Sudo Reboot
  2. 5. Canbus: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5. Canbus: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The CAN board needs a bootloader so we can flash the Klipper firmware. We will use CanBoot. Download the CanBoot repository:
    • git clone https://github.com/Arksine/CanBoot
    • cd CanBoot
    • make clean
    • make menuconfig
  3. 5. Canbus, EBB36 v1.0: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Micro-controller Architecture > (STMicroelectronics STM32)
    • Processer model > STM32F072
    • Build CanBoot Deployment Application > (Do not build)
    • Bootloader offset > (8KiB bootloader)
    • Clock Reference > (8 MHz)
    • (500000) CAN bus speed
    • Communication interface > (CAN bus (on PB8/PB9))
  4. 5. Canbus, EBB36 v1.2: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Processer model > STM32G0B1
    • Communication interface > (CAN bus (on PB0/PB1))
    • Application start offset > (8KiB offset)
  5. 5. Canbus: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5. Canbus: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Add the 5v jumper. Connect the USB-C from the Pi to the EBB36 board.
    • Put the EBB36 into DFU mode
    • Press and hold the RESET + BOOT button. Release the RESET button while holding the BOOT button, than release the BOOT button.
    • Get the device ID of the board after it's in DFU mode
    • Before DFU mode
    • In DFU mode
  6. 5. Canbus: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5. Canbus: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Erase and flash the firmware
    • sudo dfu-util -a 0 -D ~/CanBoot/out/canboot.bin --dfuse-address 0x08000000:force:mass-erase:leave -d DEVICE:ID
    • Power off the system. Plug in the 4 wire CAN cable from the UT0C to the EBB36, and power on the the printer and RPI.
    • After the system is powered up verify the CAN network is up.
    • cd klipper
    • python3 lib/canboot/flash_can.py -q
    • You should see 1 entry for application CanBoot. Note your UUID.
  7. 5. Canbus: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Run
    • cd ~/klipper
    • make menuconfig
    • Select the following
    • Enable extra low-level configuration
  8. 5. Canbus: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • continued:
    • Save the configuration pressing ESC > Yes
    • Run
    • make clean
    • make
  9. 5. Canbus, EBB36 v1.2: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  10. 5. Canbus: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 5. Canbus: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 5. Canbus: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • flash the EBB36 with the newly compiled firmware
    • python3 ~/CanBoot/scripts/flash_can.py -i can0 -f ~/klipper/out/klipper.bin -u 9fd4db4bdbc0
    • sudo dfu-util -a 0 -d 0483:df11 --dfuse-address 0x08000000 -D ~/CanBoot/out/canboot.bin
    • If all goes well your CAN board should now be flashed
    • run
    • ~/klippy-env/bin/python ~/klipper/scripts/canbus_query.py can0
    • Load the provided files to the printer and press FIRMWARE_RESTART
    • Checking the Machine tab you should see the 4 systems
David Husolo
crwdns2935283:006/16/21crwdne2935283:0
9,192 crwdns2915208:0crwdne2915208:0
crwdns2935297:033crwdne2935297:0
crwdns2942667:0crwdne2942667:0 993
