4Sight 9 Charging Port Replacement
    1. 4Sight 9 Charging Port Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 4Sight 9 Charging Port Replacement, Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
    2. 4Sight 9 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
    3. 4Sight 9 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 4Sight 9 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
    1. 4Sight 9 Charging Port Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
    2. 4Sight 9 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 4Sight 9 Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
      • Put pressure on the connector until the clasp comes undone.
      • Gently pull up on electrical ribbon until it disconnects from circuit board.
    3. 4Sight 9 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 4Sight 9 Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the second electrical ribbon from the motherboard.
      • Use the technique for the previous ribbon.
    4. 4Sight 9 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
    5. 4Sight 9 Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 4Sight 9 Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • With fingers, grip the green Wi-Fi connector.
      • Gently pull up on connector to remove tape holding the connector in place.
    6. 4Sight 9 Charging Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers, gently lift the motherboard.
    1. 4Sight 9 Charging Port Replacement, Charging Port: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use soldering gun and when solder is malleable, lift up on the left side of the charge port until it is not connected to the board with tweezers.
      • Charging port may be very hot due to soldering iron.
      • Repeat this step on right side of charging port.
Robert Shredow
crwdns2935283:004/07/15crwdne2935283:0
185 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-2, Plummer Spring 2015 crwdns2935289:0Eastern Washington University, Team 1-2, Plummer Spring 2015crwdne2935289:0
EWU-PLUMMER-S15S1G2
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 1,745
