3DS XL SD Card Cover Replacement
  1. 3DS XL SD Card Cover Replacement, Remove back panel + battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DS XL SD Card Cover Replacement, Remove back panel + battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you have a stylus, SD card or a game cartridge in the console, take them out
  2. 3DS XL SD Card Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
  3. 3DS XL SD Card Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DS XL SD Card Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set it aside.
  4. 3DS XL SD Card Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DS XL SD Card Cover Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
  5. 3DS XL SD Card Cover Replacement, Open the shell: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DS XL SD Card Cover Replacement, Open the shell: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
  6. 3DS XL SD Card Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DS XL SD Card Cover Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 6.2 mm screws using a Phillips #00 screwdriver
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #00 screwdriver.
    • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
  7. 3DS XL SD Card Cover Replacement, Detach top from bottom: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DS XL SD Card Cover Replacement, Detach top from bottom: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the upper case from the rest of the device and set aside.
  8. 3DS XL SD Card Cover Replacement, Replacing SD Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DS XL SD Card Cover Replacement, Replacing SD Cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 golden, 2.3 mm screws located around the stylus slot with a Phillips #00 screwdriver.
  9. 3DS XL SD Card Cover Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DS XL SD Card Cover Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a pry tool, lift up the thin metal plate above the SD Card Cover.
  10. 3DS XL SD Card Cover Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DS XL SD Card Cover Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly bend the silicone (Light Gray) part and pull the cover out of the device.
Ben
crwdns2935283:010/06/23crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 63
crwdns2936753:030crwdne2936753:0 301
crwdns2942667:0crwdne2942667:0 3,604
