3DR Solo Leg Replacement
  1. 3DR Solo Leg Replacement, Propeller: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the arm, which is located underneath the propeller, with one hand, and with your dominant hand grip the center of the propeller.
  2. 3DR Solo Leg Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the propeller from the locked to unlocked position as indicated by the images of the lock.
    • You will need to twist in this direction for 2-3 full rotations before the propeller will detach.
  3. 3DR Solo Leg Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the propeller off the motor.
    • To remove the silver-top propellers, repeat these steps, turning the propellers in the opposite direction of the black-top propellers.
  4. 3DR Solo Leg Replacement, Leg: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the controller on a flat surface with the battery side down.
  5. 3DR Solo Leg Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 3DR Solo Leg Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 3DR Solo Leg Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the leg and remove the two 10mm screws that hold the leg in place.
  6. 3DR Solo Leg Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the leg up to remove it from its position.
    • Leg should be connected by a black wire.
  7. 3DR Solo Leg Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 3DR Solo Leg Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 3DR Solo Leg Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the rubber grip at the end of the leg and, with your thumb, peel it back and pull it off.
  8. 3DR Solo Leg Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DR Solo Leg Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Leg type 1 will contain a 1mm screw at the base of the leg.
    • Unscrew the 1mm screw located at the end of the leg.
  9. 3DR Solo Leg Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the black cord up to release it from the leg.
  10. 3DR Solo Leg Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 3DR Solo Leg Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 3DR Solo Leg Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Leg type 2 will contain the antenna wire.
    • Gently pull up on and remove the plastic covering labeled "solo antenna".
    • Locate the antenna wire and carefully pull up and remove it.
    • The antenna wire is flimsy so use caution upon removal.
Leia Harlow
crwdns2935283:009/11/17crwdne2935283:0
104 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team S2-G3, Bruce Fall 2017 crwdns2935289:0CSU Fullerton, Team S2-G3, Bruce Fall 2017crwdne2935289:0
CSUF-BRUCE-F17S2G3
crwdns2942667:0crwdne2942667:0 403
