32" Hisense LED TV Screen Replacement
  1. 32" Hisense LED TV Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 32" Hisense LED TV Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • DO NOT plug the TV into power at any time during this process.
    • To begin, lay the TV screen-down on a smooth surface.
    • Unscrew the screws connecting both support legs to the TV.
  2. 32" Hisense LED TV Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 32" Hisense LED TV Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To begin removing the back plate, find and remove all 18 screws indicated with the Phillips screwdriver.
    • If the screws are difficult to find, remove any screws on the back plate that have an arrow pointing to them like in the second picture.
    • Once all of the screws are removed, carefully pop off the back plate without damaging any of the connected wires.
  3. 32" Hisense LED TV Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the power cord free from its metal framework.
    • After the power cord has been moved, remove the four screws keeping the housing in place. Once finished, remove the housing as well.
  4. 32" Hisense LED TV Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 32" Hisense LED TV Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three silver screws connecting the circuit board to the rest of the TV that are circled in the picture using the Phillips screwdriver.
    • Remove the final silver screw, making sure to avoid disconnecting any of the wires that obscure it from view.
  5. 32" Hisense LED TV Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all of the 18 screws connecting the front frame to the back of the TV with the Torx screwdriver.
  6. 32" Hisense LED TV Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws are all removed, slide the flat-head screwdriver into the small gap between the front and back plates. Use the screwdriver to pry the plates apart and lift the back plate up.
  7. 32" Hisense LED TV Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely separate the back from the front and flip the back section over so that the screen is now on top.
  8. 32" Hisense LED TV Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the cable pictured and detach the plastic film protecting the circuitry to which the cable is attached.
    • DO NOT detach both ends of the plastic. Only detach the end that is easily removed from its adhesive.
  9. 32" Hisense LED TV Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After detaching the plastic, detach the wire connecting the screen to the rest of the TV.
    • Next, the circuitry needs to be removed from the TV itself. Lift the screen circuitry free from the adhesive and then lift the screen free from the back section of the TV.
  10. 32" Hisense LED TV Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 32" Hisense LED TV Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that the screen has been removed, take the new screen and attach its circuitry in the same place as the previous screen. After that, connect the cable from the rest of the TV to the screen's port and it should be good to go!
    Hi i need a screen replacement cos mine is broken how can i get it am at limpopo mokopane town
    Kgabale Phillimon - crwdns2934203:0crwdne2934203:0
    Hi as i have sade i need hisense 32D screen replacement am at mokopane limpopo province how can I get it I sold apritiate if help
    I need hisense 32 inch led screen. How much an in Ebonyi state of Nigeria
    Agbo Chidiebere O - crwdns2934203:0crwdne2934203:0
crwdns2935229:023crwdne2935229:0
Connor French
crwdns2935283:009/29/15crwdne2935283:0
1 367 crwdns2915208:0crwdne2915208:0
crwdns2947412:026crwdne2947412:0
Where can I buy the replacement panel?
Arinah Arin - crwdns2934203:0crwdne2934203:0
Could you please post the panel code of this tv model (32H3C)? I guess it could be the same my hisense tv need . It could help me to find the right spare part.
Thx
Alexis - crwdns2934203:0crwdne2934203:0
where can i buy Hisene LCD TV Screen pls?
H Te Tea - crwdns2934203:0crwdne2934203:0
where do I buy a replacement screen for 32inch hisence smart tv
Shaik Ahmed Khaleck - crwdns2934203:0crwdne2934203:0
How can I buy the 55inch screen. The straight TV not curve
Solomon - crwdns2934203:0crwdne2934203:0
Where can i buy 32” Hisense LED TV display
Model number - LEDN32D50
Mkhokeli Ndebele - crwdns2934203:0crwdne2934203:0
Where can i buy 47 inch Hisense led tv display
faisaljanna - crwdns2934203:0crwdne2934203:0
I want to fix my Hisense tv. 50NT.
scott graham - crwdns2934203:0crwdne2934203:0
can someone please help me, I accidentally pulled the three wires (red, White and black) out of the little plug that plugs into the screen itself, the plug has got 5 connectors
Carlo - crwdns2934203:0crwdne2934203:0
where i can buy screen replacement for 32inch hisence smart tv ?
Tan-tan de Leon - crwdns2934203:0crwdne2934203:0
I have a doble image in a hissense LED tv. What can I do for fix ir?
Jorge Canto - crwdns2934203:0crwdne2934203:0
where to buy replacement parts and scree for hisense tv in south africa
Antony Chibidi - crwdns2934203:0crwdne2934203:0
letshego molahloe - crwdns2934203:0crwdne2934203:0
Where can I buy a replacement tv screen panel (I cracked my tv screen). For a 32’ hisense model 32H4030F1
Monique Gomez - crwdns2934203:0crwdne2934203:0
Where can I buy a replacement tv screen for hisense 32k370
swimmer man - crwdns2934203:0crwdne2934203:0
Pls where can I buy Hisense led 50”screen for replacement
Gamal dozz - crwdns2934203:0crwdne2934203:0
Where can I get 55” sceen Hisense,and how much that would cost me
Ayanda Mpu - crwdns2934203:0crwdne2934203:0
Hi is this group still active?
Phelz - crwdns2934203:0crwdne2934203:0
Hello, kindly assist me in replacing my 32 inch screen
VIOLET MUCHUKA - crwdns2934203:0crwdne2934203:0
Help please I need a screen replacement for a 43 inch Roku tv hisense model 43r6e3
twomoons88 - crwdns2934203:0crwdne2934203:0
Where can I buy replacement screen for ledn32d30 hisense
Christian Onwubalili - crwdns2934203:0crwdne2934203:0
Hi my 40nch Hisense in only display half of a screen the other half it blink in small stripes or just becomes blank in black.
What could be the problem or can I fix it
Siboniso Shange - crwdns2934203:0crwdne2934203:0
The 32” lcd tv the power is on ,red light on but the screen is no longer turning on
kuneneonke - crwdns2934203:0crwdne2934203:0
I have a 65inch Hisense tv, the LED is broken, where can I get a replacement?
Reward Masuku - crwdns2934203:0crwdne2934203:0
I need a replacement for my 43inch Hicense Tv LED
Valentine Ezeh - crwdns2934203:0crwdne2934203:0
Were can I by screen replacement 32 inch led tv hisense
Domingos - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 231
crwdns2942667:0crwdne2942667:0 53,400
