2055 Poulan Chainsaw Carburetor Seal Replacement
  1. 2055 Poulan Chainsaw Carburetor Seal Replacement, Drain fluids: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Drain gas and chain oil into proper storage containers.
  2. 2055 Poulan Chainsaw Carburetor Seal Replacement, Removing Covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Removing Covers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Removing Covers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove top cover screws (3) using a #6 flat head screw driver on the chainsaw T-wrench.
    • Loosen the 1/4" nuts holding the bar cover in place using the chainsaw T-wrench.
    • Turn the chain tension adjustment screw two turns counter clockwise.
    • Remove the nuts holding the bar cover in place, and then remove the bar.
    • Remove fly wheel cover using a 5/32" Allen wrench.
  3. 2055 Poulan Chainsaw Carburetor Seal Replacement, Removing the Carburetor: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Removing the Carburetor: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Removing the Carburetor: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the air filter from the housing.
    • Remove the air filter housing using a 8 mm socket.
    • Disconnect the two fuel lines from the carburetor using a narrow, flat-head screw driver.
    • Disconnect the throttle linkage from the carburetor.
    • Lift the choke linkage out of the housing, and then pull the carburetor from the housing.
  4. 2055 Poulan Chainsaw Carburetor Seal Replacement, Carburetor Disassembly (Lower Cover): crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Carburetor Disassembly (Lower Cover): crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Carburetor Disassembly (Lower Cover): crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws holding the diaphragm cover plate, and then remove the plate.
    • Remove the diaphragm and its seal from the carburetor.
    • Remove the screw holding the float set and needle valve.
    • Be careful to ensure that the assembly does not spring apart as the float set is under spring tension.
    • Remove the float set and needle valve.
  5. 2055 Poulan Chainsaw Carburetor Seal Replacement, Carburetor Disassembly (Top Cover): crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Carburetor Disassembly (Top Cover): crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Carburetor Disassembly (Top Cover): crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw holding the fuel pump cover in place using the chainsaw T-wrench.
    • Remove the fuel pump gasket and valve.
    • Remove the fuel filter screen.
  6. 2055 Poulan Chainsaw Carburetor Seal Replacement, Jet cleaning: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the adjustment needle retaining clip.
    • Remove both adjustment needles while counting the number of turns required for the removal.
    • Clean and reinstall the needles, turning the same number of turns that were counted in the previous step.
    • Replace the retaining clip.
  7. 2055 Poulan Chainsaw Carburetor Seal Replacement, Rebuilding fuel pump: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Rebuilding fuel pump: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align a new fuel pump valve and gasket with the carburetor.
    • Reattach the fuel pump top cover using the chainsaw T-wrench.
  8. 2055 Poulan Chainsaw Carburetor Seal Replacement, Diaphragm rebuild: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Diaphragm rebuild: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Diaphragm rebuild: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Install a new float set and needle valve.
    • Install the float set and needle valve retaining screw.
    • Place a new diaphragm and seal in position.
    • Replace the diaphragm cover and the four retaining screws.
  9. 2055 Poulan Chainsaw Carburetor Seal Replacement, Reinstalling the carburetor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Reinstalling the carburetor: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Reinstalling the carburetor: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Attach the fuel lines and the throttle linkage to the carburetor.
    • The line coming directly from the fuel tank connects to the fuel pump inlet.
    • The line coming from the external primer bulb goes to the diaphragm inlet.
    • Reinstall the throttle linkage.
  10. 2055 Poulan Chainsaw Carburetor Seal Replacement, Reinstalling air filter and housing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinstall the air filter housing, securing it with the 8 mm nuts.
    • Place the air filter back into the housing.
  11. 2055 Poulan Chainsaw Carburetor Seal Replacement, Replacing covers: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Replacing covers: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2055 Poulan Chainsaw Carburetor Seal Replacement, Replacing covers: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the top cover back in position and secure it using the flat-head screw driver.
    • Place the fly wheel cover on and secure it using the 5/32'' Allen wrench.
    • Place the bar, chain, and cover back on. Secure the cover with the two cover nuts and the socket wrench that is included on the T-wrench.
The chainsaw is now ready for gas and chain oil.
K. Niblock
crwdns2935283:011/28/17crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
Engine Engineers crwdns2935289:0Engine Engineerscrwdne2935289:0
Community
crwdns2936753:030crwdne2936753:0 84
crwdns2942667:0crwdne2942667:0 4,385
