This is a simple and easy to follow guide on how to replace the cabin air filter in a 2023 Toyota RAV4 XLE Hybrid.
The air cabin filter is responsible to catch any small particles or debris that could have entered your A/C. It is best to replace your cabin air filter every 15,000 miles or 24,000 Km. This can vary depending if your air coming from your A/C smells funny, which the problem is the cabin air filter being over used.
While purchasing the cabin air filter, be aware that you purchase the correct size for the 2023 Toyota RAV4 XLE Hybrid. I have provided a link to purchase the acquired part in this guide.
Open the glove compartment in the passenger seat area.
Carefully detach the support bar from the glove compartment.
Use both hands to push inward to release the plastic holders on both sides.
Carefully lower the glove compartment down.
You will have access to the filter compartment and cover.
Pinch the right side of the filter cover and pull toward you; it should come out with ease.
Pull out the old filter from the compartment.
Grab your new filter and place it into the compartment.
Pinch to adjust the filter in the compartment.
Insert the compartment back into the filter compartment.
Place the cover back on the filter compartment.
Do not forget to attach the support bar back to the glove compartment.
You can close the glove compartment. The plastic holders should click back to place.
You have finally replaced the cabin air filter!
By the end of this guide you have successfully replaced the cabin air filter on a 2023 RAV4 XLE Hybrid. Enjoy your clean air!
